animateme
#1 Posted : Wednesday, August 18, 2010 10:07:31 AM(UTC)
animateme
Hello,
I am hoping that I can get some help here. Our dishwasher no longer dries. I notice that the Heating Element is not heating up. I tested it and got a reading of 18 Ohms. From what I have researched online, it seems like this model does not have a thermostat, correct? If this is the case and the Heating Element is not the issue, what else could I check and how?
Thanks in advance for any help provided.
Estate (by Whirlpool)
TUD3000Y-5
Joe / APP Team
#2 Posted : Wednesday, August 18, 2010 10:59:14 AM(UTC)
Joe / APP Team
Originally Posted by: animateme Go to Quoted Post
Hello,
TUD3000Y-5
Your element checks OK (resistance is in range) so you're correct about that.
However, there is a thermal fuse(thermostat) that also has to be a closed circuit (infinite resistance). it is located on the bottom of the tub(looks like a little white box).
You may want to trace the orange wire at the heater terminal back to the thermal fuse.
And then,
There's the 3 button selector switch on the control panel.
When you select heated dry the switch contacts should close(infinite resistance) between red and white w/ red stripe.
When you select normal / air dry the circuit should open.
If those all check OK, the last possibility would be a bad heater circuit in the timer or a broken wire in the harness between any of those 3 components.
Good luck,
animateme
#3 Posted : Wednesday, August 18, 2010 12:50:00 PM(UTC)
animateme
Thank you very much for your response.
I'll check the fuse, the selector switch, and possible broken wires. If all those result OK, I'll be asking back for help on diagnosing the Timer.
Thanks again.
Joe / APP Team
#4 Posted : Wednesday, August 18, 2010 2:18:47 PM(UTC)
Joe / APP Team
Thanks again.
OK, not a problem,
That's what we're here for.
Hope you don't need a timer, but it,s a possibility.
:cool: :cool: :cool:
KitchenAid Dishwasher Not drying (Dishwasher Repair)
by louie@DFW 4/8/2022 5:15:51 PM(UTC)
Amana Dishwasher Not Drying The Dishes (Dishwasher Repair)
by mark@homeplanco.com 9/21/2020 7:32:33 AM(UTC)
Dishwasher not drying dishes (Dishwasher Repair)
by Danmrobertson 1/24/2016 9:14:27 AM(UTC)
GE dishwasher not drying dishes (Dishwasher Repair)
by dace109 1/16/2016 10:04:24 AM(UTC)
Electrolux dishwasher not drying after heater replacement (Dishwasher Repair)
by mvmone 7/1/2015 11:37:30 AM(UTC)
Dishwasher not drying, new heating element didn't help (Dishwasher Repair)
by madonid@hotmail.com 6/27/2015 9:34:02 AM(UTC)
Dishwasher Not Drying (Dishwasher Repair)
by tlhiv 11/10/2014 1:27:24 PM(UTC)
Dishwasher not drying - high-limit/temp thermostat or heating element? (Dishwasher Repair)
by tom_in_atl 1/20/2014 7:44:08 AM(UTC)
by J-net 1/15/2014 10:51:32 AM(UTC)
Dishwasher Not Drying Dishes (Dishwasher Repair)
by CMGLAZE 1/1/2014 3:14:43 PM(UTC)
dishwasher not drying but element OK? (Dishwasher Repair)
by hamiltzp 11/26/2013 11:47:37 AM(UTC)
Dishwasher not drying but heating element is good (Dishwasher Repair)
by kgates123 8/30/2012 11:49:19 AM(UTC)
Dishwasher Not Drying and Not advancing from cycle to cycle (Dishwasher Repair)
by Travelcathy 8/12/2012 2:15:38 PM(UTC)
dishwasher not drying (Dishwasher Repair)
by venom79 5/31/2012 8:42:37 AM(UTC)
Dishwasher not drying (Dishwasher Repair)
by njbxgirl 4/28/2012 7:25:12 PM(UTC)
