retcop320
#1 Posted : Tuesday, September 11, 2007 3:18:41 PM(UTC)
retcop320
I need of assistance: My gas dryer operates normally but will not heat. I have replaced the thermostat but this dos not seem to be the problem. Please Help !!!
Admin / APP Team
#2 Posted : Tuesday, September 11, 2007 4:41:13 PM(UTC)
Admin / APP Team
Rank: Administration
Which thermostat and for what reason?
Open this diagram. Remove #39 plug, start the dryer on TIMED DRY and look through the hole. Give it about 20 seconds, does the igniter glow?
If it does, replace the coils (see below). If it does not, could be a bad flame sensor, burnt igniter, or bad thermal fuse. All can be checked with an ohmmeter for continuity.
- Replacement gas valve coils
- Replacement igniter
- Replacement flame sensor
- Replacement thermal fuse
Gas dryer will not heat up (Dryer Repair)
by Ahhnother8 10/9/2014 8:16:39 PM(UTC)
GE harmony profile gas dryer will not heat (Dryer Repair)
by Thespiderman20 9/10/2013 5:44:45 PM(UTC)
Gas dryer will not heat (Dryer Repair)
by PhilWi 10/19/2012 12:50:42 PM(UTC)
Maytag gas dryer will not heat (Dryer Repair)
by jsweeyor 10/2/2012 12:15:23 PM(UTC)
GE gas dryer will not heat (Dryer Repair)
by kthorson 9/27/2012 4:30:00 AM(UTC)
by RickWilliams 10/25/2010 11:45:37 AM(UTC)
Whirlpool Kirkland Gas Dryer Will Not Heat Up (Dryer Repair)
by LITTLE RED ROOSTER 1/29/2010 9:11:39 AM(UTC)
Kenmore gas dryer will not heat (Dryer Repair)
by mcclr 10/24/2009 5:51:31 PM(UTC)
by sch8891 10/13/2009 8:26:20 AM(UTC)
Maytag Gas Dryer will not heat up fully - princeton (Dryer Repair)
by brian.frasco@gmail.com 12/26/2008 1:28:44 PM(UTC)
by Ron S 11/30/2008 1:28:06 PM(UTC)
Whirlpool gas dryer will not heat. (Dryer Repair)
by brae 11/22/2007 5:52:59 AM(UTC)
maytag gas dryer will not heat after initial burn (Dryer Repair)
by Agustin 8/27/2007 3:21:24 PM(UTC)
