jrespen
#1 Posted : Wednesday, July 28, 2010 1:54:45 PM(UTC)
jrespen
I have a Kenmore Elite model# 15962990 that is not draining. It was working properly and then just stopped. when I try to drain it I hear a buzzing like the motor is trying to work, but is not spinning. it buzzes for a while and then shuts off. I checked to see if it was clogged and that is not the case. I have also reset several times to no avail. Any suggestions?
#2 Posted : Wednesday, July 28, 2010 5:03:34 PM(UTC)
Does it wash?
Remove the bottom access panel and check if there are a water marks on the motor. If there are any, replace the pump & motor assembly.
- The pump & motor assembly Part number: AP3776467
jrespen
#3 Posted : Wednesday, July 28, 2010 5:52:24 PM(UTC)
jrespen
Thanks Gene,
A pricey part, but it looks like the right fix. I pulled the cover off and the motor is corroded. Looks like this has been going on for a while.
thanks again,
#4 Posted : Wednesday, July 28, 2010 6:21:17 PM(UTC)
You are welcome.
It is expensive but at least it's not too difficult to replace it yourself. Keep us posted.
jrespen
#5 Posted : Saturday, August 7, 2010 12:31:21 PM(UTC)
jrespen
I finally found time to install the new motor. Works great, and was an easy swap. However the new motor does make a clicking sound as if the impeller is hitting something internally. I hope that is not a sign that the motor will fail already? Thanks for the help Gene.
#6 Posted : Saturday, August 7, 2010 12:59:06 PM(UTC)
You are welcome. It's hard to say why the new pump makes such noise. One of possibilities is if a foreign object got inside. Hopefully it will go through after a few cycles.
Guest (6)
