paula8315
#1 Posted : Saturday, July 17, 2010 6:40:32 PM(UTC)
paula8315
HI,
My dryer was working earlier, I did put a larger amount of clothes when it quite. The breaker is ok and I tested the out let 3 prong 220 ok. Went and got a analog meter tried testing all the wires but truth I HAVE NO IDEA WHERE TO PUT THEM. either way I didn't get anything to show on the meter. I only tested the timer and start switch on the back. Do I need to take it apart further? Thanks
Paula:(
paula8315
#2 Posted : Saturday, July 17, 2010 8:13:31 PM(UTC)
paula8315
I got the dryer apart, I've tested the door switch is shows contiv. not sure what all the parts are called but I believe i have tested everything but the motor (there is one in the front on the bottom with 4 quick connections and on on the back at the bottom with 2 quick connections they all have contiv.) In order to get to the motor it seam as though i would have to take the drum off.) Any suggestions any one??????
Paula:)
Dryer Will Not Run Unless Knob Is Held (Dryer Repair)
by Dixiedogs99 12/10/2017 5:41:06 PM(UTC)
Dryer will not run on no heat setting (Dryer Repair)
by rgarris1969 3/11/2017 6:59:15 PM(UTC)
Dryer will not run after changing plastic shims (Dryer Repair)
by Craig Lee 1/30/2017 4:09:05 AM(UTC)
Dryer Will not Run without manual turn of Drum (Dryer Repair)
by Cadman07 9/17/2015 6:58:08 AM(UTC)
Kenmore Elite Dryer will not run for more than a second...have done lots of troublesh (Dryer Repair)
by The_Wizard 11/10/2014 4:39:55 PM(UTC)
Dryer will not run (Dryer Repair)
by kaostheory09 9/7/2014 1:04:46 PM(UTC)
Dryer will not run at all. (Dryer Repair)
by Kabbybarty 1/15/2014 6:34:36 PM(UTC)
Electric Roper Dryer will not run anymore (Dryer Repair)
by twsno 6/6/2013 4:12:17 PM(UTC)
whirlpool dryer will not run !!!!! (Dryer Repair)
by onestress 3/20/2012 6:39:02 PM(UTC)
Roper Dryer will not run (Dryer Repair)
by stevel75 2/26/2012 9:03:36 AM(UTC)
Electric Dryer will not run (Dryer Repair)
by nickfuhs 12/11/2011 1:04:29 PM(UTC)
Frigidaire dryer will not run (Dryer Repair)
by jchalfant 9/17/2010 5:57:01 AM(UTC)
Dryer Will Not Run (Dryer Repair)
by lamodj 7/12/2010 8:37:57 AM(UTC)
by pstulken 5/11/2010 7:06:53 AM(UTC)
by MILTPD 5/5/2010 3:53:45 PM(UTC)
