29 Pages«<89101112>»
#91 Posted : Friday, July 9, 2010 5:44:16 PM(UTC)
You are welcome. Thank you for your good words.
Marshrat
#92 Posted : Tuesday, July 13, 2010 8:26:00 PM(UTC)
Marshrat
Gene,
I have a Whirlpool black double oven, model number RBD306PBD12. Same error code issue; unplugged the control ribbon, turned the power back on and it is now showing E1 F2 error code. Do I need the panel or the board?
Marshrat
#93 Posted : Wednesday, July 14, 2010 6:29:34 AM(UTC)
Marshrat
Now this morning after several hours of being plugged back in the screen is blank; all there is is an occasional short beep, longer beep, beep beep beep.
#94 Posted : Wednesday, July 14, 2010 10:36:24 AM(UTC)
The error code "F2-E1" means that the control senses the key pad ribbon cable disconnected.
Inspect the ribbon cable for a hairline cracks with a magnifying glass. If there is nothing wrong, plug it back into the control board connector, power up the oven and watch the display. Try to set the time of the day. Post the result.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL RBD306PDB12 | AppliancePartsPros.com
Marshrat
#95 Posted : Thursday, July 15, 2010 6:31:03 AM(UTC)
Marshrat
powered up, screen lit up, then went to clock with PF message. Reset the clock and it is working fine for right now. If it does not last...???
Marshrat
#96 Posted : Thursday, July 15, 2010 6:41:08 AM(UTC)
Marshrat
after about 1/2 hour now, the clock display is fading out for a 1/2 second or so every so often but comes back on....
#97 Posted : Thursday, July 15, 2010 2:56:02 PM(UTC)
Most likely the problem is a bad control board, but there is a small chance for the low voltage transformer (#7 on the diagram) and the control panel to be bad as well. I would replace the control board first, hoping it will solve the problem.
- The control board Part number: AP3767567
Marshrat
#98 Posted : Thursday, July 22, 2010 7:16:47 AM(UTC)
Marshrat
Got the part yesterday, hooked it up and all seems to be working fine. Thank you very much for your help and expertise! Anything I should watch for that might indicate another problem?
#99 Posted : Thursday, July 22, 2010 1:01:17 PM(UTC)
You are welcome. I'm glad to hear that the new control board solved the problem.
There is not much what you can do to prevent it in the future.
Mr.B12
#100 Posted : Tuesday, August 3, 2010 1:27:20 PM(UTC)
Mr.B12
Hi Gene,
It's me again. It's been while since my last post but I took your advice and returned the control board and ordered another one (part AP3595759 (8302319). I got the new part and installed it over the weekend and I'm still getting the same E1 F5 error code. I'm running out of options here and I don't really want to buy new unit or pay an arm and a leg for someone else to fix it. Any thoughts on what I should try next? As always, your advice is greatly appreciated it. Thanks.
Whirlpool fault code E6 F2 (Oven Repair (including Ranges and Cooktops))
by msdabbert 11/26/2009 8:21:35 PM(UTC)
