maizenbluman
#1 Posted : Wednesday, July 7, 2010 7:48:46 PM(UTC)
maizenbluman
I have a question regarding the installation of a defrost heater kit on a Frigidaire side by side, model FRS26H5ASB5. I removed the cover over the coils and found the wires for hook up but I am having trouble knowing where to route the heater as it was removed already.
FridgeDoctor
#2 Posted : Thursday, July 8, 2010 6:26:28 AM(UTC)
FridgeDoctor
The heater is mounted at the bottom of the evaporator, and is usually held in place with metal clips/brackets. However, due to the process needed to install that heater, which I believe is going to look like an "L", you have to pull the bottom of the evaporator away from the wall. I would HIGHLY RECOMMEND you dont try this yourself, because without proper training, you can damage part of the evaporator coil by bending it, in a way similar to kinking your garden hose, and if you do that, that is a MAJOR repair, and VERY expensive. I would seriously consider calling a local refrigerator repair company and have them install that for you.
Defrost heater kit (Refrigerator & Freezer Repair)
by Jmccarr55 5/10/2010 1:06:28 PM(UTC)
Need help installing Defrost Heater Kit (part wr51x10101) (Refrigerator & Freezer Repair)
by eomolina 4/15/2010 2:43:20 PM(UTC)
by James Gray 5/12/2009 12:06:34 PM(UTC)
