How do I replace the bake element. I got to it and removed three screws holding it down - I just don't know what it is attached to in the two holes in the back of the oven and how to disconnect it?
Thank you for your help. It was so easy to remove a small plate on the back of the oven and replace the bake element. Between replacing the keypad and the bake element myself, I saved a few hundred dollars. According to what the repairman told me it would cost for him to fix it, I could have replaced the whole oven! I should've contacted you first - then I would've saved the $86.00 walk-in-the-door fee. And, it felt good to accomplish this myself!
