LuvDoc204
#1 Posted : Monday, May 26, 2008 10:55:38 AM(UTC)
LuvDoc204
This is my mother-in-laws dryer.
She is not sure of this dryers age.
She called me when the dryer stopped working.
Nothing happens when the start button is pushed.
There is 220 at the outlet.
Checked with voltmeter.
I can hear the timer running door opened or closed.
The fuses checked OK (three I believe).
Door switch checked OK.
Motor has continuity to the windings.
Checked with ohm meter.
Any suggestions?
Thanks.
richappy
#2 Posted : Monday, May 26, 2008 11:03:37 AM(UTC)
richappy
There is a thermal fuse on the heater housing, hard to see and replace, probably bad. Comes as a kit AP415996
LuvDoc204
#3 Posted : Tuesday, May 27, 2008 7:51:44 PM(UTC)
LuvDoc204
I had to search for a while before I finally found that fuse.
That was not easy to find but I got it replaced.
I also replaced the belt.
I put it back together and it ran fine.
I made sure the vent was clear.
However, when I went to start it again, all I heard a hum.
The drum would not turn.
It would start to turn if I pushed the door switch and gave the drum a push but as soon
as I let go of the door switch and tried to start it with the door closed, it would just hum.
richappy
#4 Posted : Wednesday, May 28, 2008 2:47:05 AM(UTC)
richappy
Seems like you now have a bad motor.
okbobcats
#5 Posted : Wednesday, May 28, 2008 3:06:22 AM(UTC)
okbobcats
or you have the belt on wrong
Dryer Will Not Run Unless Knob Is Held (Dryer Repair)
by Dixiedogs99 12/10/2017 5:41:06 PM(UTC)
Dryer will not run on no heat setting (Dryer Repair)
by rgarris1969 3/11/2017 6:59:15 PM(UTC)
Dryer will not run after changing plastic shims (Dryer Repair)
by Craig Lee 1/30/2017 4:09:05 AM(UTC)
Dryer Will not Run without manual turn of Drum (Dryer Repair)
by Cadman07 9/17/2015 6:58:08 AM(UTC)
Kenmore Elite Dryer will not run for more than a second...have done lots of troublesh (Dryer Repair)
by The_Wizard 11/10/2014 4:39:55 PM(UTC)
Dryer will not run (Dryer Repair)
by kaostheory09 9/7/2014 1:04:46 PM(UTC)
Dryer will not run at all. (Dryer Repair)
by Kabbybarty 1/15/2014 6:34:36 PM(UTC)
Electric Roper Dryer will not run anymore (Dryer Repair)
by twsno 6/6/2013 4:12:17 PM(UTC)
whirlpool dryer will not run !!!!! (Dryer Repair)
by onestress 3/20/2012 6:39:02 PM(UTC)
Roper Dryer will not run (Dryer Repair)
by stevel75 2/26/2012 9:03:36 AM(UTC)
Electric Dryer will not run (Dryer Repair)
by nickfuhs 12/11/2011 1:04:29 PM(UTC)
Frigidaire dryer will not run (Dryer Repair)
by jchalfant 9/17/2010 5:57:01 AM(UTC)
by paula8315 7/17/2010 6:40:32 PM(UTC)
Dryer Will Not Run (Dryer Repair)
by lamodj 7/12/2010 8:37:57 AM(UTC)
by pstulken 5/11/2010 7:06:53 AM(UTC)
