nsimone1056
#1 Posted : Wednesday, May 14, 2008 6:34:59 PM(UTC)
nsimone1056
I put a bathmat that gave off a lot of lint in my washer and it apparently clogged the drain/filter. Is there any way to unclog it myself or do I need a repairman for this job?
nsimone1056
#2 Posted : Wednesday, May 14, 2008 7:01:54 PM(UTC)
nsimone1056
Sorry, it's a Roper Super capacity washer, model #RAS8244LQ1
#3 Posted : Thursday, May 15, 2008 3:05:54 PM(UTC)
This is not too difficult job to do it yourself.
Remove the washer cabinet and the water pump. Remove the hoses from the water pump and clean them. The pump is better to replace.
Here are the complete instructions - How to remove the washer cabinet & the water pump.
- The part number for the water pump is AP2907492
Here are the break down diagrams for the Roper washer Model RAS8244LQ0
nsimone1056
#4 Posted : Friday, May 16, 2008 7:01:10 AM(UTC)
nsimone1056
Thanks so much, I'll give it a try this weekend. I just couldn't figure out how to get the cabinet off. Once I do that, the repair should be simple.
nsimone1056
#5 Posted : Monday, May 19, 2008 7:31:35 AM(UTC)
nsimone1056
Gene,
followed your instructions (beautiful!) and was able to unclog the pump and get it back on. The washer is spinning and it drained without any clothes in it, but when I added a small load of wash I just can't get all the water to drain out. It almost seems like it's not spinning very hard/fast but it's hard to tell since I'm usually not watching it when this is going on!
Any other ideas?
Thx!
smsix
#6 Posted : Wednesday, May 21, 2008 11:31:37 AM(UTC)
smsix
my older model crosley washer will not aggitate and hums when it is suppose to be aggitating or draining is this the motor?
#7 Posted : Thursday, May 22, 2008 4:17:15 PM(UTC)
nsimone1056,
Is it water inside or just wet clothes?
Did you check the pump impeller?
#8 Posted : Thursday, May 22, 2008 4:18:13 PM(UTC)
smsix,
In order to provide most accurate advise we need the complete model number of the washer.
Guest (6)
Whirlpool Dishwasher Won't Drain Completely, I hear Pump Running... (Dishwasher Repair)
by Guest 4/18/2022 5:39:50 PM(UTC)
Bosch SHU33 dishwasher won't drain when hot just after a wash (Dishwasher Repair)
by Guest 7/12/2021 7:43:33 AM(UTC)
Maytag washer won't drain with clothes (Washer Repair)
by Guest 7/8/2021 3:20:36 PM(UTC)
Bosch dishwasher won't drain, begins cycle, then stops - FIXED (Dishwasher Repair)
by mabradbury 1/17/2019 7:08:25 PM(UTC)
Bosch dishwasher won't drain completely (Dishwasher Repair)
by nathaniel.hoffman@gmail.com 12/25/2018 6:30:47 AM(UTC)
GE dishwasher won't drain after last rinse cycle (Dishwasher Repair)
by autotech1 1/22/2018 9:47:40 AM(UTC)
Dishwasher won't drain (Dishwasher Repair)
by Drummabouy 6/22/2017 6:29:14 AM(UTC)
Washer won't drain (Washer Repair)
by jpowell1978 2/23/2017 5:58:30 PM(UTC)
Dishwasher Won't Drain or Run Cleaning Cycle (Dishwasher Repair)
by Katie L 8/4/2016 2:07:24 PM(UTC)
Bosch Dishwasher won't drain and goes directly to "Clean" Light (Dishwasher Repair)
by ed3120 6/4/2016 4:40:01 AM(UTC)
by brokenge 2/18/2016 2:32:59 PM(UTC)
Frigidaire dishwasher won't drain (Dishwasher Repair)
by kohanz 12/4/2015 9:35:55 PM(UTC)
Washer won't drain!!! (Washer Repair)
by Bdelay24 11/5/2015 6:27:01 PM(UTC)
Dishwasher won't drain! (Dishwasher Repair)
by Crafter_Man 10/12/2015 4:30:35 AM(UTC)
Top load washer won't drain... (Washer Repair)
by Gigler90x 7/28/2015 7:38:09 PM(UTC)
