2 Pages12>
Kmcduffie
#1 Posted : Tuesday, April 13, 2010 11:34:26 AM(UTC)
Kmcduffie
how do i replace the belt on my washer white westinghouse WWX433RBW2 model ?
#2 Posted : Tuesday, April 13, 2010 3:03:59 PM(UTC)
You have to remove the front panel in order to access the belt. Unscrew two screws on the bottom of the front panel and slide it down.
- The belt Part number: AP3867042
Kmcduffie
#3 Posted : Tuesday, April 13, 2010 8:44:33 PM(UTC)
Kmcduffie
the problem I am having is not with removal of panel but it is with the actual belt installation on pulleys, i dont know how the tensioner comes into play with belt install .
#4 Posted : Wednesday, April 14, 2010 2:58:03 PM(UTC)
Hopefully the attached picture will help.
File Attachment(s):
Top load washer belt.doc (77kb) downloaded 298 time(s).
Kmcduffie
#5 Posted : Wednesday, April 14, 2010 4:31:50 PM(UTC)
Kmcduffie
Thanks A Million, They Say A Picture Is Worth A Thousand Words It Help And The Washer Is Working Fine
Kelvin
#6 Posted : Wednesday, April 14, 2010 7:52:25 PM(UTC)
Kelvin,
I'm glad you were able to do it.
Ms. Vette
#7 Posted : Thursday, June 10, 2010 6:05:11 AM(UTC)
Ms. Vette
:confused: I have an older White-Westinghouse washer - Model# LA640JXW3. The washer is not spinning or agitating. I have identified the problem. The pulley wheel is broken and the belt is worn. I went out and purchase a new pulley wheel and belt, but I am having a hard time with the installation of the belt on the pulley. I just cannot get it on there. I tried to put the warn belt back on. I will work for a few moments and fall off. Can anyone give me an idea of what I am doing incorrectly?
#8 Posted : Thursday, June 10, 2010 4:29:04 PM(UTC)
Try to push in the idler pulley while installing the new belt.
Here are the breakdown diagrams and Replacement parts for FRIGIDAIRE LA640JXW3 Wwh(v2) / Top Loading Automatic Agitator Washer | AppliancePartsPros.com
hartley.singer
#9 Posted : Friday, May 27, 2011 1:41:09 PM(UTC)
hartley.singer
I need to replace washer belt on WHite Westinghouse model LA800M
getyler2
#10 Posted : Monday, February 17, 2014 7:26:52 AM(UTC)
getyler2
Would the replacement work and belt be the same for a model MWX413REW1? My belt is screaming on spin cycle now as well. Many thanks Gene!
Guest (7)
2 Pages12>
