20 Pages«<678910>»
#71 Posted : Friday, April 9, 2010 6:46:40 PM(UTC)
Originally Posted by: qiqiangzhu Go to Quoted Post
I will try to open the top panel tomorrow.
The toe panel, on the bottom.
qiqiangzhu
#72 Posted : Saturday, April 10, 2010 7:41:01 PM(UTC)
qiqiangzhu
I opened the toe panel few days ago, but it's difficult to check continuity on coil and igniter, since they are deep inside.
I hesitate to open the top panel, and remove the drum with belt, since I have some bad experience last time when I changed the belt on other gas dryer.
qiqiangzhu
#73 Posted : Sunday, April 11, 2010 11:51:41 AM(UTC)
qiqiangzhu
Will it be the problem on the dryer's timer?
This is a coin-operated dryer, ever since I started this machine, it didn't stop, I can only unplug the power cord. But when I plug it back in, and push the start button, it started again.
If the timer broken, no flame/heat will be in the dryer, right?
How to check the timer?
qiqiangzhu
#74 Posted : Sunday, April 11, 2010 6:29:38 PM(UTC)
qiqiangzhu
I've disconnected the igniter power cord (See the picture) and tested the voltage on it when the power is on, it doesn't have 110v, it has only 30v. What went wrong?
qiqiangzhu attached the following image(s):
qiqiangzhu
#75 Posted : Sunday, April 11, 2010 6:34:04 PM(UTC)
qiqiangzhu
Here is the timer.
How to test if it's failed or not.
Why a bad timer will affect the heating process?
qiqiangzhu
#76 Posted : Monday, April 12, 2010 11:20:23 PM(UTC)
qiqiangzhu
The timer part for this coin-operated dryer may not be produced by Whirlpool, it maybe a third party product?
#77 Posted : Tuesday, April 13, 2010 11:55:21 AM(UTC)
According to the wiring diagram, the power to the heater comes from the switch "B" (the top switch on your picture) through the high limit thermostat (#15 on the diagram), operating thermostat (#8) and thermal fuse (#6).
All of these parts have to be checked for continuity with the wires removed from their terminals. The timer switch has to be tested while the timer is in "ON" position. Redo all tests and post the results.
qiqiangzhu
#78 Posted : Tuesday, April 13, 2010 2:38:08 PM(UTC)
qiqiangzhu
I checked all the parts in back of the range again, including high limit thermostat, operating thermostat and thermal fuse, they all have continuity.
I reached the dryer(heat) censor today, remove a wire from one of the terminal, no continuity; put the wire back, has continuity. Does this mean dryer(heat) censor is broken?
I've also checked the voltage on the ignitor when the dryer was turned on, it didn't have 110v, only had about 30v. Why is that?
Btw, this video looks very close to my dryer.
YouTube - How to troubleshoot a gas dryer (No Heat)
#79 Posted : Tuesday, April 13, 2010 3:21:50 PM(UTC)
Have you checked the timer switch "B"?
Which part did you call "dryer (heat) sensor"?
qiqiangzhu
#80 Posted : Tuesday, April 13, 2010 4:05:38 PM(UTC)
qiqiangzhu
The top square box(actually it's the left-most parts in the dryer), with blue and white wires.
According the video, he calls this dryer sensor/heat sensor.
UserPostedImage
Maybe should be called as Flame sensor.
UserPostedImage
Guest (15)
20 Pages«<678910>»
