207 Pages«<7778798081>»
#781 Posted : Friday, April 9, 2010 10:19:12 AM(UTC)
You are welcome Jody. I'm glad your refrigerator is back in business.
Slashz28
#782 Posted : Friday, April 9, 2010 10:20:18 AM(UTC)
Slashz28
^^ Thanks Gene. I spoke to someone in the area (appliance repair guy) and he seemed pretty certain that the thermostat is likely the culprit (said he sees it often). I'll swap the thermostat and see how that goes. If that doesn't fix it, I'll follow your troubleshooting steps further.
Thanks again!
Tom
#783 Posted : Friday, April 9, 2010 10:30:28 AM(UTC)
Tom,
I believe so, but... Anyway, good luck and keep us posted.
Slashz28
#784 Posted : Friday, April 9, 2010 11:09:39 AM(UTC)
Slashz28
Gene, since you're around, would you know offhand where it would be located? Here's a link to a breakdown http://www.****************.com/index.php?ma...agram_id=94958, and # 30 is the thermostat, but there is no thermostat on the diagram. I'm sure it'll take me no time to find it anyway, but if I do know exactly where to look to begin with it'd make things quicker still : )
where you see ****, it should be ****************.... dunno why it did that
Cheers
TV
#785 Posted : Friday, April 9, 2010 11:33:13 AM(UTC)
The defrost thermostat should be on or around the evaporator, behind the rear panel in the freezer.
goodshink
#786 Posted : Saturday, April 10, 2010 10:56:15 AM(UTC)
goodshink
I have replaced the main control board and the upper thermistor.I jumped the control board and the heater glowed red. My freezer coils are still icing up. What else could be causeing this? I have a GE side by side. Please help!
vudinh
#787 Posted : Saturday, April 10, 2010 11:41:52 AM(UTC)
vudinh
I had samsung side by side model number RS2520SW,the freezer side work fine,but the fridge it warm not deforst I put new thermasted and heater still not deforst.What else can I do?
TJ17
#788 Posted : Tuesday, April 13, 2010 12:31:58 PM(UTC)
TJ17
Hi Gene,
Been in circles with our GE Profile freezer bottom the last month or so... About 6 weeks ago our fridge got warm, freezer was fine. Repair guy switched out the main board / 24 hr defrost and it worked for fine for a month. Then we had the same problem. This time he says the main board is fine but, can't find the problem. Cool air comes through to the fridge only when the freezer is open. We've cleared all food so nothing is blocking... Any ideas?
THANK YOU!:confused:
#789 Posted : Tuesday, April 13, 2010 12:37:52 PM(UTC)
What is the complete model number of the refrigerator?
#790 Posted : Tuesday, April 13, 2010 12:40:23 PM(UTC)
Perform the troubleshooting as described in the attached instructions.
Here are the breakdown diagrams and Replacement parts for MAYTAG RS2520SW Ref - Sxs | AppliancePartsPros.com
File Attachment(s):
Refrigeration Troubleshooting.doc (645kb) downloaded 19 time(s).
Guest (11)
