9 Pages«<34567>»
nguyeko
#41 Posted : Friday, April 2, 2010 1:53:21 PM(UTC)
nguyeko
Yes! Check the timer terminals between black and red wires as well. It has continuity. I replaced the thermastats because I ordered it thinking the thermastats was the issue. Anyway, the dryer runs w/ the drummer rolls but still no heat. What could be the problem if those were not the issue? The timer seems to work as well.
Korry-
Korry,
Did you disconnect the wires from the parts before the continuity tests?
If your answer is "Yes", then check for continuity between the timer terminals BK (black) and R (red) while the timer is in any auto or timed dry position. The wires should be removed from those terminals.
#42 Posted : Monday, April 5, 2010 8:15:56 PM(UTC)
Korry-
Everything checks OK, but there is no heat... It can not be like that. Very likely something was wrong with the tests. You may want to start it from scratch.
nguyeko
#43 Posted : Wednesday, April 7, 2010 5:56:41 PM(UTC)
nguyeko
Thanks Gene. It turned out the heating element is bad. There are 4 terminals in the vicinity. I was mistaken w/ the 2 other terminals. The heating element ONLY has one wire connected to its terminal. Anyway, after replaced the heating element, it works perfectly.Thanks again.
Korry-
qiqiangzhu
#44 Posted : Wednesday, April 7, 2010 6:52:10 PM(UTC)
qiqiangzhu
Why you keep tell us check the voltage for 220v?
Mine is a Whirlpool gas dryer, model # CG2951XYW3. From the manual, it uses 110v.
#45 Posted : Wednesday, April 7, 2010 7:14:46 PM(UTC)
Korry-
Korry,
I'm glad to hear you were able to fix it. Good job!
Thank you for the feedback.
#46 Posted : Wednesday, April 7, 2010 7:18:23 PM(UTC)
Did we tell you to check voltage for YOUR DRYER?
It should be done for electric dryers only.
What is wrong with your dryer?
qiqiangzhu
#47 Posted : Wednesday, April 7, 2010 7:21:02 PM(UTC)
qiqiangzhu
No heat, sir.
The drum is turning normally though.
I will check continuity tomorrow and let you know the result.
qiqiangzhu attached the following image(s):
#48 Posted : Wednesday, April 7, 2010 7:25:48 PM(UTC)
The first part you may want to check is the thermal fuse (#6 on the diagram).
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL CG2951XYW3 | AppliancePartsPros.com
qiqiangzhu
#49 Posted : Wednesday, April 7, 2010 7:28:14 PM(UTC)
qiqiangzhu
Where is it?
On the right side above or left side bottom?
File Attachment(s):
#50 Posted : Wednesday, April 7, 2010 11:27:57 PM(UTC)
It's on the left side bottom.
The thermal fuse Part number: AP3132867
No dryer heat (Dryer Repair)
by adamson 8/9/2009 3:11:05 PM(UTC)
No Dryer Heat/No shut of in auto cycle (Dryer Repair)
by fred2117 4/30/2009 2:09:57 AM(UTC)
No Dryer Heat (Dryer Repair)
by jackd3 10/6/2007 5:06:10 AM(UTC)
9 Pages«<34567>»
