How do I adjust the oven door hinges? I was changing the convection fan, overbalanced, and leaned heavily on the door. Now the door gaps at the top.
Make sure the inner door liner, oven door frame and door hinges are not bend. The door hinges are not adjustable.
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Make sure the inner door liner, oven door frame and door hinges are not bend. The door hinges are not adjustable.
Gene. Gene, Thanks for the input. FYI, I found a rotating stop on each hinge. I rotated the stops down to the hinge and closed the door. Then I applied closing pressure on the door and the hinges realigned themselves. The oven door now closes like new.
Good to hear it. I'm glad it was that simple.
I see how he talks about fixing the issue below, and I am having the same issue.
How did he get to the hinges? and this totating stop?
