pwrply2
#1 Posted : 17 years ago
pwrply2
The dryer won't work when you push the button to start. We checked the door switch, its fine, and the timer is not broken and the fuses on the circuit to the house are fine. Its a 220V outlet. What else could it be?
fixtec90
#2 Posted : 17 years ago
fixtec90
First check the pigtail (cord) at the dryer. They sometimes burn up at the terminal block. After that check your t-stats by jumping them out. Don't miss the small one on the side of the heater. If the small t-stat on the side is bad you must also replace the larger one on top of the heater. They come as a kit.
dryer not running (Dryer Repair)
by SteveDB 9 years ago
Dryer not running (Dryer Repair)
by CComperry 11 years ago
Maytag Performa dryer not running (Dryer Repair)
by bluex 11 years ago
Kenmore Elec Dryer not running on air dry/no heat on all cycles (Dryer Repair)
by jmm53 12 years ago
by Michael Walsh 13 years ago
by Steven R Henderson 13 years ago
Dryer not running!!! (Dryer Repair)
by mjones375 14 years ago
Electric clothes dryer not running! (Dryer Repair)
by jjblum2002 15 years ago
Frigidaire Dryer Not Running (Dryer Repair)
by QuarlJ01 15 years ago
dryer not running thru full cycle (Dryer Repair)
by 30tredog 16 years ago
dryer not running suddenly (Dryer Repair)
by Ellie69 16 years ago
