Michael Walsh
#1 Posted : 13 years ago
Michael Walsh
The dryer will not turn on. I have checked and there is power to the unit.
The timer is making a little noise but thats it. I think it needs to be replaced part # 53-1810 but want to be sure.
Mike
Simon / APP Team
#2 Posted : 13 years ago
Simon / APP Team
Groups: APP Team
Hi.
Here are the breakdown diagrams and Replacement parts for Admiral LNC7764A71 DRYER- ELE | AppliancePartsPros.com
On the diagram #4 locate thermostat #3 and fuse #5.
Check them both for continuity.
They are sold as a kit Part number: LA-1053
Thank you. Post the results.
Simon.
kayakcrzy
#3 Posted : 13 years ago
kayakcrzy
Usually the reason the thermal fuse goes out is because of a back up of lint build-up!! So be real sure, you take the front off of the dryer. Once the top is up on the dryer, you will see a 1/4 inch screw, on the top left corner, on the inside of the front, and one on the right corner. Then pull the front off, I am sure you will see a ton of lint. appliance educator
dryer not running (Dryer Repair)
by SteveDB 9 years ago
Dryer not running (Dryer Repair)
by CComperry 11 years ago
Maytag Performa dryer not running (Dryer Repair)
by bluex 11 years ago
Kenmore Elec Dryer not running on air dry/no heat on all cycles (Dryer Repair)
by jmm53 12 years ago
by Steven R Henderson 13 years ago
Dryer not running!!! (Dryer Repair)
by mjones375 14 years ago
Electric clothes dryer not running! (Dryer Repair)
by jjblum2002 15 years ago
Frigidaire Dryer Not Running (Dryer Repair)
by QuarlJ01 15 years ago
dryer not running thru full cycle (Dryer Repair)
by 30tredog 16 years ago
dryer not running suddenly (Dryer Repair)
by Ellie69 16 years ago
by pwrply2 17 years ago
