armackzum
#1 Posted : Monday, March 15, 2010 12:18:25 PM(UTC)
armackzum
I've checked continuity on every sensor I can find. Heating element has continuity. Motor runs when direct wired to 115V.
Lint basket in door was clogged.
Could moisture sensor be culprit? Should this moisture sensor show continuity?
magician59
#2 Posted : Monday, March 15, 2010 12:39:37 PM(UTC)
magician59
Did you check to see if you have 240VAC at the outlet? Also check the door switch.
armackzum
#3 Posted : Monday, March 15, 2010 1:10:00 PM(UTC)
armackzum
Yes 240 is present at outlet. Door switch(door must be closed switch) has continuity.
Thanks,
magician59
#4 Posted : Monday, March 15, 2010 1:25:27 PM(UTC)
magician59
If you have continuity in al the thermostats and the thermal fuse; and the door switch functions properly, I would suspect a bad timer.
armackzum
#5 Posted : Monday, March 15, 2010 6:04:20 PM(UTC)
armackzum
Door switch has continuity. Does moisture switch require continuity? Would the moisture switches failure to have continuity prevent Dryer operation?
Thanks,
magician59
#6 Posted : Monday, March 15, 2010 7:20:35 PM(UTC)
magician59
Thanks,
The moisture sensor has one wire that goes to chassis ground, and another to the heat control board. They can fail, only if there is a broken or disconnected wire, but their failure would not keep the dryer from working. To test the sensor's continuity, pull it out of the dryer body and disconnect one of the wires. Moisten the bars with a damp washcloth as you check between the two terminals.
armackzum
#7 Posted : Tuesday, March 16, 2010 11:22:07 AM(UTC)
armackzum
I am going to recheck the continuity on the thermo overheat swiitch on the lint vent. Everthing checks out so I am going to recheck that thermo non resetable switch. I would welcome any recomendations to check anything else that cause a complete "no response" with power at 240 wall outlet.
Thanks,
magician59
#8 Posted : Tuesday, March 16, 2010 1:11:49 PM(UTC)
magician59
The thermal fuse, door switch, the timer, and the start switch are the only components that, when one (or all) fails, will cause a No-start condition as you describe.
#9 Posted : Wednesday, March 17, 2010 1:36:24 PM(UTC)
Here are your parts includes a wiring diagram
Replacement parts for MAYTAG PYE4557AYW Dryer - Ele | AppliancePartsPros.com
I know you have checked for the 240 volts but have you checked for the 120 sides.
L1 to Neutral and L2 to Neutral should be 120 volts.
If you loose Neutral then you loose the 120 but still have the 240.
Guest (6)
