Originally Posted by: Fastlanedan ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) There should be instruction -come with ALL new thermostat with varieous configuration. One of the configuation should say; Heatpump with two stage heating. there should be intruction on where to hook up your aux. device.(any color wire is ok, as long as it is hook up per diagram. follow the diagram)
I will see if I can look up yor particular thermostat. Sorry, but I do not see a diagram. Biggest problem I have is L, B, and C. L says "or F", B says "or H but thought B is common on Trane, and C says "or B or X"- just can't understand this- THANKS
I don't have your exact model. but your user manual should have it. it will look like this.
Originally Posted by: Fastlanedan ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I don't have your exact model. but your user manual should have it. it will look like this. I had to experiment a little but got everything hooked up- found that my biggest problem was a Dip Switch in the Zone Control Board that had to be switched on- next project will be other HVAC system in upper part of house- system works great!! THANK YOU GUYS, fastlanedan and hillbilly for all your help!!!
