3 Pages<123
mooney99
#21 Posted : Sunday, March 7, 2010 9:23:04 PM(UTC)
mooney99
Originally Posted by: Fastlanedan Go to Quoted Post
There should be instruction -come with ALL new thermostat with varieous configuration. One of the configuation should say; Heatpump with two stage heating. there should be intruction on where to hook up your aux. device.(any color wire is ok, as long as it is hook up per diagram. follow the diagram)
I will see if I can look up yor particular thermostat.
Sorry, but I do not see a diagram. Biggest problem I have is L, B, and C.
L says "or F", B says "or H but thought B is common on Trane, and C says
"or B or X"- just can't understand this- THANKS
Fastlanedan
#22 Posted : Tuesday, March 9, 2010 9:21:31 AM(UTC)
Fastlanedan
I don't have your exact model. but your user manual should have it. it will look like this.
File Attachment(s):
thermodisc PDF-productCatalog.pdf (518kb) downloaded 11 time(s).
mooney99
#23 Posted : Tuesday, March 9, 2010 12:57:59 PM(UTC)
mooney99
I had to experiment a little but got everything hooked up- found that my biggest problem was a Dip Switch in the Zone Control Board that had to be switched on- next project will be other HVAC system in upper part of
house- system works great!!
THANK YOU GUYS, fastlanedan and hillbilly for all your help!!!
3 Pages<123
