DJH
#1 Posted : Thursday, April 10, 2008 1:07:27 PM(UTC)
DJH
Hello,
2 of the 4 spark igniters on my stove top have stopped working consistently. When I turn the knob to the "iite" position, it doesn't spark like the other burners that work. Some times it works, but most of the time it doesn't. I called GE and they said that I can order a replacement electrode and replace it myself; however, they won't be sending instructions with the parts. Is this an easy part to replace by myself? I pulled out the electrode and it was attached to a wire. Any advice would be much appreciated. Thanks.
#2 Posted : Friday, April 11, 2008 10:58:03 AM(UTC)
If you already pulled out the electrode - you went more then half way. The wire just plugs into the electrode. Pull it out and plug into the new electrode.
But...
The first thing I would check is the ceramic part of the ignition electrode. If it's not broken and not cracked - it's fine.
If there is nothing wrong with the ceramic insulation then the problem is a bad spark module (located inside the control panel).
- The part number for the ignition electrode is AP2020574
- The part number for the spark module is AP2020570
DJH
#3 Posted : Friday, April 11, 2008 3:32:44 PM(UTC)
DJH
thank you for responding so quick...is the spark module easy to replace on our own? DJH
#4 Posted : Friday, April 11, 2008 3:36:43 PM(UTC)
Yes, this part is not too difficult to replace yourself. Remove the rear cover from the control panel and you'll see it.
DJH
#5 Posted : Sunday, April 27, 2008 6:51:16 PM(UTC)
DJH
Thanks you so much for your help. We replaced the spark module and it has fixed the problem. All 4 burners ignite without any problems. You saved us a lot of money and time. Thanks again.
#6 Posted : Monday, April 28, 2008 5:38:53 PM(UTC)
I'm glad you were able to fix it.
Guest (6)
