dmeiss
#1 Posted : Friday, February 19, 2010 4:51:24 AM(UTC)
dmeiss
Hi:
Dryer is struggling to turn with heavy loads (usually jeans). It seems to turn fine with lighter (or no) loads. The belt seems snug. I changed the front & rear bearings last year.
Is the motor going south on me? Or is the belt maybe not as tight as it needs to be?
Thanks in advance for your help.
sidfink43
#2 Posted : Monday, February 22, 2010 11:32:45 AM(UTC)
sidfink43
Check your bearings again, something may have gotten hung up but if everything is ok then it probably is the motor.
dmeiss
#3 Posted : Tuesday, February 23, 2010 11:11:36 AM(UTC)
dmeiss
Thanks for the response.
If I change the motor, do I also need to change the pulley, or anything else while I'm in there?
sidfink43
#4 Posted : Tuesday, February 23, 2010 1:04:34 PM(UTC)
sidfink43
I would put on a new belt and change out the tension pulley just so you don't have to go in and do anything else again for the foreseeable future.
