Microwave has no power what so ever. Worked fine the day before. Next morning noticed that there was no power. Checked the outlet and the line fuse and it seems fine. What else could it be? Where is the thermal fuse located?
Thanks in Advance.
There are two thermal fuses. One is located on the magnetron and another one is located on top of the left side of the cavity under the air duct. The microwave has to be removed from the cabinet to access the second one. - The part number for the cavity thermal fuse is AP3038826 - The part number for the magnetron thermal fuse is AP3745043 Gene.
