:confused: The Whirlpool manuel states "pry emblem off from front of washer trim and remove T-20 torx screws" The Kenmore Calypso does not have an emblem on the front of the top.
Rank:: Advanced Member
There are 2 push clips about 4 inches from left and right corners inward.. push them in and raise top... remove the clips while you work on it so when you lay top down for any reason it wont snap shut again on you
Originally Posted by: bambiblaster ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) There are 2 push clips about 4 inches from left and right corners inward.. push them in and raise top... remove the clips while you work on it so when you lay top down for any reason it wont snap shut again on you Thanks! it worked just great
