Jeff_S7
#1 Posted : Sunday, March 23, 2008 11:23:28 AM(UTC)
Jeff_S7
Hello - my refr/freezer stopped cooling. We were told by a local tech that the Defrost Timer was stuck, and should be replaced. However, after finding the part number on it (TMDG823VB9), I have not been able to locate a replacement. If I can't find the exact part, can I swap it out for a part with the same specs? 120 VAC, SW1-2 125 VAC 10a, SW1-4 125 VAC 1/3 HP. Much Thanks --- Jeff
Montgomery Ward, Signature 2000 by Admiral, HMG 19804
#2 Posted : Monday, March 24, 2008 10:23:28 AM(UTC)
Hi Jeff,
Before replacing the defrost timer I would recommend to perform your own troubleshooting as described in one of previous posts: http://forum.appliancepartspros...frigerator-too-warm.html to make sure what's wrong with your fridge.
The model number you posted does not look like a valid Montgomery Ward model number.
Verify the model number and if this is the only one available, then we need you to post a pictures of a faulty parts you found.
Defrost timer replacement (Refrigerator & Freezer Repair)
by Joe Calypso 4/26/2014 8:01:11 AM(UTC)
Amana bottom freezer defrost timer replacement (Refrigerator & Freezer Repair)
by blackketter 8/23/2012 9:01:36 AM(UTC)
by lismarmis 7/21/2009 6:28:17 AM(UTC)
