My Side by side is accumulating ice on the floor of the freezer. Does anyone know why?
Hi fvetampa Most likely the problem with your fridge is a clogged and frozen up drain. The drain is located on the bottom under the rear panel inside the freezer. You can use a hair dryer to defrost the drain and a few cups of hot water to run through. - For the future references here are the break down diagrams for the Maytag refrigerator Model MSD2454GRWGood luck. Gene.
