mbeal
#1 Posted : Wednesday, January 27, 2010 1:32:49 PM(UTC)
mbeal
the washer has a digital board which will not come on therefore cannot turn it on replaced the elec control unit but was not the problem anything else i could check
sidfink43
#2 Posted : Thursday, January 28, 2010 3:59:47 PM(UTC)
sidfink43
Since you did not post a model number I am assuming you have the basic Calypso. There was some changes in the part, see this listing.
Part number: AP3837551
If you have it connected ok, check to see if power is getting to the board.
Here is a service manual for the Calypso which may help.
https://secured.whirlpoo...4632a4/$FILE/8178010.pdf
Make sure all your contacts are clean and well seated.
If all checks out your interface board may be the problem.
Whirlpool Calypso slow, noisy spin cycle (Washer Repair)
by supergm7 11/16/2015 4:22:13 PM(UTC)
dryer error code, Whirlpool Calypso (Dryer Repair)
by vanduser99 8/5/2012 6:50:21 AM(UTC)
Whirlpool Calypso Dryer - error code 05 (Dryer Repair)
by goffa 2/2/2012 8:41:04 AM(UTC)
Whirlpool Calypso won't spin (Washer Repair)
by techatronic 7/24/2011 5:12:02 PM(UTC)
whirlpool calypso dryer (Dryer Repair)
by kirtiswilliams53 6/8/2011 4:28:57 PM(UTC)
Drain pump motor on whirlpool calypso washer (Washer Repair)
by mike0123 4/9/2011 7:17:34 AM(UTC)
whirlpool calypso washing machine cuts out (Washer Repair)
by tross 3/11/2011 3:50:33 PM(UTC)
Whirlpool Calypso Water Level Switch (Washer Repair)
by diyhelp 12/20/2010 6:14:21 AM(UTC)
Whirlpool Calypso Washer (Dishwasher Repair)
by indy4300 8/25/2010 1:02:28 PM(UTC)
Whirlpool Calypso washer (Washer Repair)
by srspaceman 5/19/2010 2:28:29 PM(UTC)
Whirlpool Calypso Electric Dryer - E1 error code (Dryer Repair)
by kleverkn 4/25/2010 6:34:16 AM(UTC)
Intermitent LF on whirlpool Calypso Washer (Washer Repair)
by troubledinTX 1/16/2010 12:43:05 PM(UTC)
whirlpool Calypso water leak (Washer Repair)
by Joseph Rotenberg 8/7/2009 5:52:20 AM(UTC)
Whirlpool Calypso Washer - There is power, but does not respond to any commands (Washer Repair)
by dtdiep 8/1/2008 11:48:39 AM(UTC)
