angie1963
#1 Posted : Saturday, March 8, 2008 12:14:46 PM(UTC)
angie1963
the water going to my door dispenser is not coming out. if i unplug the blue coupler under the refridgerator that connects to the water line going up inside the door to the dispenser the water will come out of that hose. it seems theres a problem with the hose running up inside the door, "like its clogged" but i've blown it out best i could with an air hose. water still will not come out the door dispenser, but it goes into the ice maker just fine. what could be causing this problem. :confused:
Thanks, thirsty :eek:
#2 Posted : Sunday, March 9, 2008 1:05:10 PM(UTC)
Originally Posted by: angie1963 Go to Quoted Post
... if i unplug the blue coupler under the refridgerator that connects to the water line going up inside the door to the dispenser the water will come out of that hose....
Did the water come out of the hose by itself or when you pushed the water release button?
Nimrag
#3 Posted : Friday, March 14, 2008 7:49:52 AM(UTC)
Nimrag
The water is frozen in the door. Major problem with GE side by side refridgerators. The door is sealed. You can leave the door open long enough to unfreeze the water line or use a hair dryer.
bears159
#4 Posted : Thursday, March 20, 2008 8:43:25 AM(UTC)
bears159
Hi,
I have the exact same problem. Unplugged blue coupler, push lever, water flows out right side of tubing. I ran pipe cleaner up through the door side, thought it was clogged. What area should I concentrate on putting the hair dryer to, to thaw the line? Pulling my hair out here!!
Thanks in advance for your help.
Shanda
Nimrag
#5 Posted : Thursday, March 20, 2008 1:43:51 PM(UTC)
Nimrag
I had good luck with opening the door and letting the door defrost, aiming the hair dryer at the water outlet (this works but takes time and you have to protect the food in the freezer). The major step I did was to cut on opening on the inside of the freeze door, remove the foam insulation to expose the water line and use the hair dryer there.
bears159
#6 Posted : Friday, March 21, 2008 6:05:40 AM(UTC)
bears159
Thank you so much for your reply. I will give a wirl on Sat. Have a Happy Easter!!
Sincerely,
Shanda
bears159
#7 Posted : Friday, March 21, 2008 6:07:01 AM(UTC)
bears159
Hello,
Thank you so much for your response. I will give this a try on Sat. Have a Happy Easter!!!
Sincerely,
Shanda
collins10s
#8 Posted : Monday, January 11, 2010 2:43:01 PM(UTC)
collins10s
I filled a coffee cup with water, heated it to boiling in the microwave then injected it into the tubing at the dispenser with a marinade syringe. It melted the ice in seconds. Be sure to put a towel under the dispenser until it thaws as water will come back out until it is clear.
mortcom
#9 Posted : Monday, January 31, 2011 8:10:18 AM(UTC)
mortcom
Great Idea! It worked for me with hot tap water and about four squirts.
Thanks,
Joel
Guest (6)
Freezer door water dispenser constantly on (Refrigerator & Freezer Repair)
by manxman 8/6/2012 2:28:50 PM(UTC)
Leaking in-door water dispenser (Refrigerator & Freezer Repair)
by Bill Calderon 5/15/2012 7:14:37 PM(UTC)
Water comes out of the door water dispenser as the ice maker fills (Refrigerator & Freezer Repair)
by rino2b 1/15/2012 6:23:55 AM(UTC)
Throught the door water dispenser dripping (Refrigerator & Freezer Repair)
by rgeronimo01 1/12/2011 9:56:54 AM(UTC)
In door water dispenser, damaged water line (Refrigerator & Freezer Repair)
by MisterTime 12/25/2010 8:10:59 PM(UTC)
Door Water Dispenser Fills Ice Maker (Refrigerator & Freezer Repair)
by dgold1988 7/11/2010 1:34:01 PM(UTC)
Thru-Door Water Dispenser Tube Replacement (Refrigerator & Freezer Repair)
by K-Dub 4/19/2010 9:43:23 AM(UTC)
Door water dispenser (Refrigerator & Freezer Repair)
by Naveen 7/3/2009 12:25:08 PM(UTC)
In-Door water dispenser does not work (Refrigerator & Freezer Repair)
by clubbber333 5/25/2009 8:29:02 AM(UTC)
Indoor water dispenser hose replacement (Refrigerator & Freezer Repair)
by JOHN BIERMAN 7/29/2007 11:45:43 AM(UTC)
