stacycat70
#1 Posted : Friday, January 22, 2010 9:56:25 AM(UTC)
stacycat70
Hi; we are trying to fix our oven and we are trying to locate a diagram of this oven so we can replace the thermometer. Does anybody have a diagram of this oven or one similar that they can share? It would be much appreciated!!:)
#2 Posted : Friday, January 22, 2010 5:10:41 PM(UTC)
Here are the breakdown diagrams and Replacement parts for MAYTAG CRE9800ACB Range - S/c F/s Ele | AppliancePartsPros.com
Which part did you call "thermometer"?
stacycat70
#3 Posted : Friday, January 22, 2010 5:45:39 PM(UTC)
stacycat70
I am a gal trying to help my grandpa fix his oven; he was an electrician back in the day and is determined to replace the thermometer. I will ask him in the morning for more information.
stacycat70
#4 Posted : Friday, January 22, 2010 6:06:21 PM(UTC)
stacycat70
It's the oven THERMOSTAT that we are trying to locate on the diagram! :)
#5 Posted : Friday, January 22, 2010 11:44:37 PM(UTC)
What exactly is wrong with the oven?
stacycat70
#6 Posted : Sunday, January 24, 2010 8:49:55 AM(UTC)
stacycat70
Gene,
The oven will not reach a temperature above 200 degrees. We already took the bottom element out and tested it at a local repair shop. It is not broken. The repair shop told us it was probably the thermostat which is bad.
#7 Posted : Monday, January 25, 2010 5:29:29 PM(UTC)
There is no any oven thermostats in your range. The oven temperature controls by the the electronic control board aka a clock/timer. Unfortunately this part is no longer available. Looks like it's time for a new range.
Here are the breakdown diagrams and Control panel replacement parts for MAYTAG CRE9800ACB Range - S/c F/s Ele | AppliancePartsPros.com
stacycat70
#8 Posted : Monday, January 25, 2010 5:37:08 PM(UTC)
stacycat70
Well, this is bittersweet news! Thanks for your time, Gene! I really appreciate it.
