Hi; we are trying to fix our oven and we are trying to locate a diagram of this oven so we can replace the thermometer. Does anybody have a diagram of this oven or one similar that they can share? It would be much appreciated!!:)
I am a gal trying to help my grandpa fix his oven; he was an electrician back in the day and is determined to replace the thermometer. I will ask him in the morning for more information.
It's the oven THERMOSTAT that we are trying to locate on the diagram! :)
What exactly is wrong with the oven?
Gene, The oven will not reach a temperature above 200 degrees. We already took the bottom element out and tested it at a local repair shop. It is not broken. The repair shop told us it was probably the thermostat which is bad.
Originally Posted by: Gene Well, this is bittersweet news! Thanks for your time, Gene! I really appreciate it.
