Thank you Gene. I will order those parts. Have a great Thanksgiving.
You are welcome. Have a great Thanksgiving as well.
Keep us posted.
My mother's having a similar issue with her Whirpool Imperial 70 Gas Dryer, Model# LG7801XKG0. This model was purchased by my father sometime in the 1980s. I cleaned the interior of lint and checked the vent for blockage to determine if that was the culprit. However, the dryer has no heat at all. I cannot locate a parts diagram for the model on the site, so I'm not sure if the troubleshooting process would be the same or if this model has the same configuration as the newer models. I would appreciate some guidance on this so I can hopefully repair it for her. She's a widow with limited funds.
Thanks.
C.S.
I have a Kenmore Gas Dryer model#11079902890 about ten years old. It will runs fine with no problems except it will not give heat at all. I checked all the possible continuity items I thought it could be. I cleaned it out of all the lint. I replaced the igniter and coils with new ones. Still no heat. The igniter does not turn on or smell gas. I used the youtube video YouTube - KENMORE DRYER REPAIR VIDEO 5 . Yes I know the video shows an electric dryer but the checking of the continuity is basically the same. Can someone please help me out. My wife is yelling at me and I can't take it anymore.:eek: She wants me to buy a new one. Unfortunately she doesn't understand the concept of "it is not in our budget right now".
Gene, I have a TGDX640JQ2 Whirlpool Estate and I am having some of the problems as stated on this forum. I have checked all continuity and all except the cycling thermo has me confused. Which terminals should you be checking acrossed on it. I get open on two of them and closed on two of them. Many thanks, BTW I really think what you do on here is great I would love to have all that knowledge about appliances, I kind of like working on them but no formal training. I have "revived" a new front load washer and dryer from a flood too that was interesting.
check to see if your ignitor is glowing. you need to remove front pannel to do this if not glowing replace. just had the same issue. also good time to vaccume out good.
Originally Posted by: adrabek ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Gene, I have a TGDX640JQ2 Whirlpool Estate and I am having some of the problems as stated on this forum. I have checked all continuity and all except the cycling thermo has me confused. Which terminals should you be checking acrossed on it. I get open on two of them and closed on two of them. Many thanks, BTW I really think what you do on here is great I would love to have all that knowledge about appliances, I kind of like working on them but no formal training. I have "revived" a new front load washer and dryer from a flood too that was interesting. According to the Wiring sheet, there are seven parts in the heating circuit besides the timer. They are: high limit thermostat (#15 on the diagram), thermal cut-off (#16), cycling thermostat (#8), thermal fuse (#6), flame sensor (#49), igniter (#4 on the diagram) and gas valve coils (#13 & #14). Have you checked for continuity all of them?The good test result for the cycling thermostat is continuity between the two large terminals. The two small terminals are for the bias heater and can not be tested with a meter. You can find how to test the gas valve coils in one of our previous posts: http://forum.appliancepartspros...er-runs-but-no-heat.htmlHere are the breakdown diagrams and Replacement parts for WHIRLPOOL TGDX640JQ2 | AppliancePartsPros.comGene. P.S. Have you verified the gas coming to the dryer?
Originally Posted by: chepito ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I have a Kenmore Gas Dryer model#11079902890 about ten years old. It will runs fine with no problems except it will not give heat at all. I checked all the possible continuity items I thought it could be. I cleaned it out of all the lint. I replaced the igniter and coils with new ones. Still no heat. The igniter does not turn on or smell gas. I used the youtube video YouTube - KENMORE DRYER REPAIR VIDEO 5 . Yes I know the video shows an electric dryer but the checking of the continuity is basically the same. Can someone please help me out. My wife is yelling at me and I can't take it anymore.:eek: She wants me to buy a new one. Unfortunately she doesn't understand the concept of "it is not in our budget right now". You probably can use the same instructions as posted for adrabek. Post the results and we'll help you with the correct part numbers. Gene.
Many thanks Gene, just after posting that I reread the instructions to test it all and somehow I missed the part about checking the thermal fuse FIRST. I don't know how I missed it but that was indeed the problem. Lucky enough we just had a dryer breakdown in our family and they got a new one so I robbed some of the parts off of it today and checked them and they were good so I am off to install them now. Once again thank you Gene from all of us on the message boards I think we will all agree it is very nice of you to help us out.
