error code F0 appears about 2 hours after the oven has been used. Hit the clear button and it goes away. A while later it comes back........Code says to replace the control panel??? Help..
Turn the power off. Open the control panel and remove the control panel ribbon from the control board. Restore the power and monitor the oven for a day. If the error code shown up again, replace the control board. If the error code disappeared, replace the control panel. - The part number for the control board (ERC) is AP3203778 - The part number for the control panel is AP3205594 Gene.
Question? Is the ribbon cable supposed to have a connector at the end of it? It appears that the ribbon end is inserted in the connector on the control board and is held in by a plastic clip..?? thanks.. Want to make sure I did not damage the ribbon cable.
Originally Posted by: yogigrogi ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Gene
Question? ... It appears that the ribbon end is inserted in the connector on the control board and is held in by a plastic clip..?? ... Yes. This is the way how it was designed. Gene.
I did remove the ribbon cable, power back on and within 5 min. error code came back on. Looks like i will order a new control erc. thanks for the help......
Keep me updated, please.
Ordered a CRC part #AP3203778. Installed it and nothing happened!!!! No clock etc.. Called Appliance Parts Pros, and they sent another CRC.. Installed it and clock worked, however after using the oven once back to the same old story!!!! Error code F0...? Ccccccccccould it be another bad ERC? Any suggestions??? thanks .
pat
Hi Pat, In such situation I would recommend to call the APP customer service to exchange the defective ERC one more time and replace the control panel together with the new ERC. - The part number for the control panel is AP3205594Gene.
