I've got the same question Lynn Wachter had on 12-11-07. My oven will pre-heat and come up to temp okay, but after that it will not maintain the set temp. It just keeps dropping. I can turn off the oven, re-set the temp, it will come back up and beep the 3 times to let you know it's there, but will not hold. I replaced the igniter, but that did not fix the problem. This happens both in regular and covection bake.
Most likely the problem with your oven caused by the control board.
I'm not able to provide the right part number for the control board due to the model number you posted is incorrect.
Verify and repost it, please.
