Replaced heating element but cannot clear the flashing clean light.
Originally Posted by: tjl1954  Replaced heating element on my Whirlpool Dishwasher Model No. DU1055XTPQ4 but cannot clear the flashing clean light.Is there a code?]
THIS FORUM IS DEAD!!!!!!! |
To Denman, I tried your solution to my problem and it did not work.Is there a sequence that I should be using?
As far as I know you just follow the sequence i the data sheet.
You cold try removing power from the unit for half an hour or so to see if that may reset it.
If that does not work then perhaps the board is blown, Did you check the original heater with a meter before replacing it? Did you check the hi-limit thermostat? |
Thank You denman,I was not following the right sequence.The dishwasher is operating.
