DustinAZ
#1 Posted : Tuesday, March 4, 2008 10:14:43 AM(UTC)
DustinAZ
have power to unit, sticker on inside of unit say something about replacing thermal cutoff and Hi limit thermostat? will this help? :confused:
#2 Posted : Wednesday, March 5, 2008 9:33:35 AM(UTC)
Hi Dustin,
In order to provide most accurate advise I need the complete model number of the dryer and more specific description of the problem.
DustinAZ
#3 Posted : Wednesday, March 5, 2008 2:06:14 PM(UTC)
DustinAZ
I'll get that info to you asap. Thanks for your help, I just moved to Northern Arizona, two hours away from a big city. I can fix just about and thing, just need some advise. Thanks again, keep an eye out for me. I should have that info tonight posted. Dustin
DustinAZ
#4 Posted : Wednesday, March 5, 2008 5:08:48 PM(UTC)
DustinAZ
Gene, thanks again, here's some info. Roper Dryer, Model# rex4625ew2 type: 122-00 I was drying some clothes, walked out to the shop to se if they were done and noticed that the clothes were still a little damp and the timer still show about mid cycle. I tried to re start and nothing, i tried the other two cycles and nothing. I tested outlet and I have power. Do you need any other info? I can fax you the wire diagram, I found it in side the top cover. Let me know what you think. Thank you so much!!!!!!:o
#5 Posted : Wednesday, March 5, 2008 6:11:57 PM(UTC)
Hi Dustin,
The first thing I would do is check the following parts for continuity:
1. The heating element (#17 on the bulkhead parts break down diagram).
2. The thermal cut-off (#6 on the bulkhead parts break down diagram).
3. The hi limit thermostat (#15 on the bulkhead parts break down diagram).
4. The cycling thermostat (#24 on the bulkhead parts break down diagram).
The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter – How to check continuity with Ohmmeter.
Any of these parts with an open circuit has to be replaced.
- The part number for the heating element is AP3094254
- The part number for the thermal cut-off (including the hi limit thermostat) is AP3094244
- The part number for the hi limit thermostat is AP3131941
- The part number for the cycling thermostat is AP3115922
Here are the break down diagrams for the Roper dryer Model REX4625EW2
Good luck.
Guest (5)
