bugladyri
#1 Posted : 17 years ago
bugladyri
My dryer is not heating at all. It's turning , and blowing through the dryer vent hose. I suspect it's the heating element.?
#2 Posted : 17 years ago
The first thing I would check is 240V at the power outlet.
If there is nothing wrong then I would check the following parts for continuity:
1. The heating element (#17 on the bulkhead parts break down diagram).
2. The thermal cut-off (#6 on the bulkhead parts break down diagram).
3. The hi limit thermostat (#15 on the bulkhead parts break down diagram).
4. The cycling thermostat (#24 on the bulkhead parts break down diagram).
The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter – How to check continuity with Ohmmeter.
Any of these parts with an open circuit has to be replaced.
- The part number for the heating element is AP3109438
- The part number for the thermal cut-off (including the hi limit thermostat) is AP3094224
- The part number for the hi limit thermostat is AP2973862
- The part number for the cycling thermostat is AP3115922
Here are the break down diagrams for the Whirlpool dryer Model LE5700XSW0
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 10 months ago
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 12 months ago
no heat from oven or broiler (Oven Repair (including Ranges and Cooktops))
by lennyag about a year ago
Dryer loud squeaking and no heat (Dryer Repair)
by hackerfam about a year ago
LG Dryer DLE2301R No Heat (Dryer Repair)
by mhess01 about a year ago
No heat when assembled (Dryer Repair)
by Guest 2 years ago
whirlpool PN# W10339417; no heating after replacing element (Oven Repair (including Ranges and Cooktops))
Whirlpool Duet Electric dryer - no heat (Dryer Repair)
by ShawnDS24 2 years ago
No heat, (Dryer Repair)
by tseibring 2 years ago
Brand New LG gas dryer , GAS code, no heat (Dryer Repair)
by lglad 2 years ago
Gas Dryer GE GFDS355GL0MS No Heat. Ignitor is good E11 error. (Dryer Repair)
by jim.starzynski@gmail.com 3 years ago
Dryer starts, does not stop, no heat (Dryer Repair)
by Guest 3 years ago
Samsung Electric Range-No Heat (Oven Repair (including Ranges and Cooktops))
by Jimh64 3 years ago
Samsung Dryer DV448AEP/XAC - no heat (Dryer Repair)
by mgmjtech 3 years ago
heeat turns on no heat comming up through floor register (Heating, Ventilation, and Air Conditioning (HVAC))
