vykefan4life
#1 Posted : Tuesday, December 15, 2009 1:05:43 PM(UTC)
vykefan4life
there is power to the unit..when i push the "normal" button the light turns green, but when i push the "start" button nothing happens except the "normal" light blinks once...the unit is not locked.... when i push the the High Temp and Energy Save button alternately a few times all the lights turn on..I then push cancel and all the lights turn off....all other lights light individually when pushed except the Start light
#2 Posted : Tuesday, December 15, 2009 2:44:00 PM(UTC)
Check the door switch(es) and make sure it's properly engaged when the door is latched. Post the results.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KUDP01FLSS1 Dishwasher | AppliancePartsPros.com
Here is the Tech sheet.
vykefan4life
#3 Posted : Tuesday, December 15, 2009 2:54:02 PM(UTC)
vykefan4life
The door seems to be working...is there a way to make sure the latch is engaged when the door is closed...is there a way to check it using the touch pad
#4 Posted : Tuesday, December 15, 2009 3:52:43 PM(UTC)
The only way to verify it is to test it with an Ohmmeter.
vykefan4life
#5 Posted : Tuesday, December 15, 2009 5:03:49 PM(UTC)
vykefan4life
i will check it..lets say it works...what could be the problem?
#6 Posted : Tuesday, December 15, 2009 5:25:24 PM(UTC)
Lets do one thing at a time.
vykefan4life
#7 Posted : Wednesday, December 16, 2009 3:29:24 PM(UTC)
vykefan4life
Thank you Gene. I appreciate your help. i have the ohmmeter, but dont how to test..do i have to remove a part of the panel to do it...or is there a way to do that without removing any of the screws...if i have to remove panel please talk me thru it :) I can unscrew the screws around the inside of door easy enough but how the rest come apart.
#8 Posted : Wednesday, December 16, 2009 4:22:23 PM(UTC)
The door has to be taken apart. You can find the instructions in the Service manual.
vykefan4life
#9 Posted : Thursday, December 17, 2009 7:53:07 PM(UTC)
vykefan4life
thanks i will let you know how that goes
vykefan4life
#10 Posted : Wednesday, December 30, 2009 8:56:36 PM(UTC)
vykefan4life
Gene...ran out of time and hd to call a repair guy...turns out it is the door latch...thank you so much for your help
