johnmw2009
#1 Posted : Tuesday, December 15, 2009 6:11:22 AM(UTC)
johnmw2009
Sorry for the confusing question from earlier. Basically my dryer takes too long to dry. The timer advances properly and shuts off with no problem. It seems as if the element is not coming on or staying on long enough or it cycles too much. I thought maybe the timer might be messed up and stuck in the low heat selection mode even when I turn it to high heat. I did not replace the timer but I did replace just about everything else. It does have an Auto drymiser selection and I am guessing that it can maybe detect the amount of moisture inside the dryer which would either increase or decrease the amount of dry time from load to load. I replaced the thermostats, element, and thermal cutoff. You said in the last response that "One thing it might do is keep the thermostat's internal heater on all the time which would keep you in a low temp mode" Were you referring to the timer? Or, is it possible that a faulty timer is causing the dryer to stay in a low temp mode? I have taken the dryer apart and thoroughly cleaned it and I also tested it, unhooked from the dryer duct/vent that leads to the outside of my house, eliminating the possibility that it might be clogged up.
#2 Posted : Tuesday, December 15, 2009 9:36:49 AM(UTC)
I took a look at your parts and the wiring diagram and noticed that the internal thermostat heater is dotted lines which usually means "Only on some models".
Also I do not see any resistors to the internal heater on the timer.
Could you please confirm that your thermostat is a 4 wire unit?
2 for it's contacts and 2 for the heater.
And is there a board in the control console that does not show up in the parts?
Whirlpool dryer light (Dryer Repair)
by Guest 6/19/2024 12:27:19 PM(UTC)
Whirlpool dryer WED7500VW1 won’t turn on (Dryer Repair)
by tryingmybest 11/15/2023 4:40:47 PM(UTC)
Whirlpool dryer wire (Dryer Repair)
by Guest 10/20/2023 10:51:08 AM(UTC)
Whirlpool dryer heavy load turning (Dryer Repair)
by Guest 3/28/2023 5:58:08 PM(UTC)
YWED7500VW0 - Looking whirlpool dryer belt access procedure (Dryer Repair)
by Toronto_18_2703 11/4/2022 12:46:25 PM(UTC)
Whirlpool Dryer Knocking Noise (Dryer Repair)
by Guest 8/31/2022 5:01:42 PM(UTC)
Whirlpool Dryer sensor light on and never starts (Dryer Repair)
by CPepe 8/27/2022 11:48:56 AM(UTC)
Whirlpool Dryer WGD5300SQ0 taking too long to dry (Dryer Repair)
by aryan 4/10/2022 3:24:26 PM(UTC)
Whirlpool Dryer Model# W10151592A (Dryer Repair)
by Ssuarez 2/28/2022 4:22:11 PM(UTC)
Whirlpool dryer WED9500TW1 (Dryer Repair)
by Herm404 12/18/2021 12:39:46 PM(UTC)
WHIRLPOOL Dryer Repair Kit (27 Inch Wide Dryers, Thin Twins) - AP3109602 (4392067) (Dryer Repair)
by try2repairguy 12/9/2021 6:57:53 AM(UTC)
Whirlpool Dryer Fan Not Working (Dryer Repair)
by kkknie 11/21/2021 12:09:24 PM(UTC)
Whirlpool Dryer WED5790VQ1 (Dryer Repair)
by Guest 10/22/2021 3:39:17 PM(UTC)
whirlpool dryer codes persist (Dryer Repair)
by JMM12 7/30/2021 4:52:44 AM(UTC)
whirlpool dryer stops on sensing (Dryer Repair)
by Guest 5/16/2021 7:46:23 PM(UTC)
