Radiant
#1 Posted : Saturday, December 12, 2009 1:30:27 PM(UTC)
Radiant
HELP-THE control panel locked on my Whirlpool Duet HT-How do I unlock it.
sidfink43
#2 Posted : Monday, December 14, 2009 5:49:26 AM(UTC)
sidfink43
See if unplugging the machine and leaving it sit for a short while will free things up. Then look inside the top for the tech notes which should show you how to put the machine into test/diagnosis mode so you can see if there is still a problem.
#3 Posted : Monday, December 14, 2009 5:59:49 AM(UTC)
Te following may help
http://www.servicematters.com/d...0Sheet%20-%208181790.pdf
Note always a good idea to use the actual sheets that came with the unit as there may be some variations.
Radiant
#4 Posted : Monday, December 14, 2009 11:38:28 AM(UTC)
Radiant
I tried unplugging it -that didn't work- I'm not sure what yuo mean by "look inside the top" I took off the top front and there is just a circuit board. I read in a manual(not Mine)that when the control lock is on it should still start. None of the buttons are functioning. Thanks for any help.
sidfink43
#5 Posted : Monday, December 14, 2009 12:01:52 PM(UTC)
sidfink43
Inside the top should have been a copy of the tech sheet, the same or similar to the one Denman referenced.
Here is a service manual for an earlier version of your machine which should give you additional information. Check to see if you have power getting to the control board, and if so and you cannot get the machine into test mode you may have to replace it on speculation that replacement will solve the problem.
https://secured.whirlpoo...ILE/Duet%20Job%20Aid.pdf
#6 Posted : Monday, December 14, 2009 12:18:42 PM(UTC)
Here is the operators manual as it sounds like yoy do not have one.
http://shared.whirlpoolc...0Guide%20-%208182042.pdf
Radiant
#7 Posted : Monday, December 14, 2009 1:04:28 PM(UTC)
Radiant
Thanks for the manual-Another free repair service said press the end of cycle button for 3 seconds and it should unlock,and it did.
sidfink43
#8 Posted : Monday, December 14, 2009 4:35:41 PM(UTC)
sidfink43
Great, thanks for the update.
mspatton8
#9 Posted : Sunday, April 9, 2017 1:42:41 PM(UTC)
mspatton8
thanks for the info. the press "end of cycle" worked for me this time.:)
Control panel locked (Dishwasher Repair)
by clenne 11/22/2011 11:00:41 PM(UTC)
Control Panel Locked Up (Refrigerator & Freezer Repair)
by vsorlie 8/11/2011 1:51:52 PM(UTC)
Control Panel Locked (Washer Repair)
by MOORELEANNA 7/9/2011 11:01:37 AM(UTC)
ge washer control panel locked (General Talk)
by michelleaarons 2/4/2009 12:42:55 PM(UTC)
