Gilbert Siu
#1 Posted : Saturday, December 12, 2009 12:19:18 PM(UTC)
Gilbert Siu
My dishwasher is a Whirlpool Model GU1500XTLQ1. I is about 6 years old. It works good but makes a high pitch sound. I was told by the service technician that the motor is bad. I am planning to replace the motor myself. Can you walk me through on how to remove the motor?:)
#2 Posted : Sunday, December 13, 2009 3:14:52 AM(UTC)
Replacement parts for WHIRLPOOL GU1500XTLQ1 Undercounter Dishwasher | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/d...0Sheet%20-%208537797.pdf
Here is the manual
https://secured.whirlpoo...520548/$FILE/8178022.pdf
Be sure to remove power from the unit.
A turkey baster come is handy to suck up any water.
A tray under the unit will help keep it off the floor, just undo things slowly so that if the tray fills you can tighten and empty the tray.
Be sure to clean any seal surfaces.
I also like to put a very light coating of lithium grease on seals, it just seems to make things go back together easier.
How to replace motor bearings on Kitchen Aid KUDSO1FLSS1 dish washer (Dishwasher Repair)
by rajfixplumming 3/1/2014 10:33:52 AM(UTC)
how to replace motor pulley (Washer Repair)
by spurs fan 7/16/2012 8:40:55 AM(UTC)
How to replace motor (Washer Repair)
by mwimv 4/20/2011 7:32:19 AM(UTC)
Help on how to Replace Motor (Dryer Repair)
by hooterz 1/10/2010 9:55:12 PM(UTC)
How to replace motor on Whirlpool dryer (Dryer Repair)
by Doug Bahniuk 7/20/2009 7:51:37 AM(UTC)
