RichardJ
#1 Posted : Friday, December 11, 2009 12:40:37 PM(UTC)
RichardJ
When troubleshooting a light problem on this microwave I pushed the two door latches in to see if the light would work. I then managed to pull the latches back out to what I think is their original position. But now, when I try to use the microwave, the door seems to close okay, but when I press start the "door" message appears and the microwave won't start.
Is there a reset or something I need to do? Help.
Richard J
#2 Posted : Friday, December 11, 2009 2:53:52 PM(UTC)
Richard,
Looks like your "experiments" caused the 20 amps fuse behind the control panel to blow out. Check it for continuity and replace if it's open. If this fuse is fine, check the 15 amps line fuse on the right side on the back of the microwave. In such situation the microwave has to be removed from the oven cabinet.
- The 20 amps fuse Part number: AP4307253
RichardJ
#3 Posted : Friday, December 11, 2009 4:22:23 PM(UTC)
RichardJ
Thanks Gene, and for being so quick on a Friday late afternoon. I'll give your solution a shot.
Next question then is how to get at the 20amp fuse behind the control panel? Can I just pull the whole combo unit partially out to get at it? Any instructions on pulling it out?
Richard J :)
#4 Posted : Friday, December 11, 2009 7:03:59 PM(UTC)
All instructions are in the Service manual. Good luck.
NC2011
#5 Posted : Friday, January 7, 2011 6:50:55 PM(UTC)
NC2011
Same problem with my Whirlpool combo. My model # is GMC305PRS01. I also made a same mistake of pushing latches in and pulling back out. May be 20 amp fuse is blown as mentioned in your note. Did you get instruction on how to get to fuse. Instruction on the link is from Kitchen aid combo not Whirlpool. Thanks
#6 Posted : Saturday, January 8, 2011 2:42:13 PM(UTC)
Kitchen Aid is a part of Whirlpool. You can use the same service manual.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GMC305PRS01 30`` BUILT-IN ELECTRIC COMBO SENSOR/SC (GOLD LINE) | AppliancePartsPros.com
hisam
#7 Posted : Friday, July 15, 2011 2:32:48 PM(UTC)
hisam
I have the same problem without doing anything to the latch. The 20A fuse read zero resistance. I supposed the fuse is OK. What else should I check? Mine is GMC275PDB07.
Guest (6)
