dzak
#1 Posted : Friday, February 22, 2008 9:35:32 AM(UTC)
dzak
Spin cycle has operating "out of balance" for a while, causing the machine to "walk". Now it is making a loud "screeching" noise. I checked the belt and it seems to be working correctly. Could it be a bearing in the motor, or something else??
#2 Posted : Friday, February 22, 2008 9:04:18 PM(UTC)
The first failure suspect is the bearing in the drain pump.
Remove the belt and check how free the pump pulley is moving.
- The part number for the drain pump is AP3447809
Here are the break down diagrams for the Maytag washer Model PAV3300AWW
richappy
#3 Posted : Saturday, February 23, 2008 3:25:01 AM(UTC)
richappy
If the pump is ok, you probably have a worn snubber; a sure indication of this is a lot of white shavings in the bottom of the washer.
dzak
#4 Posted : Monday, February 25, 2008 6:56:32 AM(UTC)
dzak
Thanks. I removed the belt and was able to turn the pump pulley pretty easily -- it wouldn't "spin" (like a bicycle wheel), but there was no grinding noise either. I did notice the pulley was sort of loose -- I could move it back and forth a quarter inch or so, like it has some "play" in it. Should I go ahead and replace it and the belt?
#5 Posted : Monday, February 25, 2008 10:21:00 AM(UTC)
I would recommend to replace the drain pump. The belt has to be replaced if it's worn.
