carynlee64
#1 Posted : Thursday, February 21, 2008 5:58:36 PM(UTC)
carynlee64
Hi, when i push on bake then start, its starts the count down like its heating up//but the oven never ignites, the stove top burners work fine, just the oven and broiler wont start, a few months ago i decided to try it again, and bingo it lit up and worked for 3 months or so..now nothing again, help please, I dont want to buy a new oven...thanks Caryn
#2 Posted : Friday, February 22, 2008 2:17:25 PM(UTC)
Hi Caryn,
In order to provide the most accurate advise I need the complete model of the unit.
The number you posted is the serial number.
roycreamer
#3 Posted : Friday, February 22, 2008 6:14:41 PM(UTC)
roycreamer
open your oven and turn on bake, look at the bottom of the oven, (actually in the small openings on the sides of the bottom) and see if it glows orange at all. if it is and it doesn't get hot, you need a new ignitor. if not, i might call a repairman.
roy
Oven wont ignite (Oven Repair (including Ranges and Cooktops))
by mjpokor 7/16/2013 8:58:40 AM(UTC)
oven wont ignite (Oven Repair (including Ranges and Cooktops))
by Ricardo25 9/3/2012 6:42:52 PM(UTC)
oven wont ignite after replacing ignitor (Oven Repair (including Ranges and Cooktops))
by tim3768 8/14/2012 2:42:06 PM(UTC)
by tech2tech 6/12/2011 6:08:54 PM(UTC)
KitchenAid Gas Oven Wont Ignite (Oven Repair (including Ranges and Cooktops))
by traveller 4/14/2011 2:51:06 PM(UTC)
gas oven wont ignite (Oven Repair (including Ranges and Cooktops))
by wkvien 1/28/2011 12:36:55 PM(UTC)
My oven wont ignite after I tightened gas leaking connector (Oven Repair (including Ranges and Cooktops))
by raminla 6/2/2010 12:14:35 PM(UTC)
Lower part of oven wont ignite (Oven Repair (including Ranges and Cooktops))
by rdanigel 8/3/2009 4:05:57 PM(UTC)
Oven wont ignite/no gas (Oven Repair (including Ranges and Cooktops))
by pavel 2/23/2008 8:07:38 AM(UTC)
by mick100 8/15/2007 8:23:04 AM(UTC)
