valarieja
#1 Posted : 17 years ago
valarieja
When I push the start button on the dryer, it turns on, but then kicks off immediately. I've tried to restart it using all the different cycle options.
I also tried to shut the breaker off for the dryer, the turned it back on, went back.... pushed the button on the dryer, same thing .. switches on, then right off again.
Not sure what else to check or to do?
#2 Posted : 17 years ago
Did it stay "on" while you kept the "start" button depressed?
Did it make any noise at start up?
If the first answer is "No" and the second is "Yes" then most likely the motor is gone bad. Unfortunately the motor for this dryer is no longer available.
valarieja
#3 Posted : 17 years ago
valarieja
The dryer only stays on for a split second and no it doesn't seem to make any noises other than normal startup stuff... just kicks right off.
#4 Posted : 17 years ago
I still believe the problem caused by the bad motor which is no longer available.
Whirlpool Dryer switch at bottom of heating element (Dryer Repair)
by Roosterwes 8 years ago
Dryer switch does not turn on. (Washer Repair)
by yalda 13 years ago
Dryer switch wiring (Dryer Repair)
by talon636 13 years ago
Repair a Dryer Switch (Dryer Repair)
by jmarkk1 13 years ago
Replaced dryer switch but won't stay on (Dryer Repair)
by taminator 13 years ago
by janrauenhorst 14 years ago
dryer switch (Dryer Repair)
by dorena vaccaro 14 years ago
Maytag dryer switch went bad (I thought) but new switch is doing the same thing. (Dryer Repair)
by woof 14 years ago
Maytag Dryer Switch Problem (Dryer Repair)
by kenkane 14 years ago
Dryer switch intermittent (Dryer Repair)
by jcw99 14 years ago
Update on dryer switch problem? (Dryer Repair)
by jhuffar 15 years ago
Need to replace dryer switch (Dryer Repair)
by cojo 15 years ago
