valarieja
#1 Posted : Monday, February 18, 2008 9:00:13 AM(UTC)
valarieja
When I push the start button on the dryer, it turns on, but then kicks off immediately. I've tried to restart it using all the different cycle options.
I also tried to shut the breaker off for the dryer, the turned it back on, went back.... pushed the button on the dryer, same thing .. switches on, then right off again.
Not sure what else to check or to do?
#2 Posted : Monday, February 18, 2008 5:08:33 PM(UTC)
Did it stay "on" while you kept the "start" button depressed?
Did it make any noise at start up?
If the first answer is "No" and the second is "Yes" then most likely the motor is gone bad. Unfortunately the motor for this dryer is no longer available.
valarieja
#3 Posted : Tuesday, February 19, 2008 4:37:26 AM(UTC)
valarieja
The dryer only stays on for a split second and no it doesn't seem to make any noises other than normal startup stuff... just kicks right off.
#4 Posted : Tuesday, February 19, 2008 7:17:54 AM(UTC)
I still believe the problem caused by the bad motor which is no longer available.
Whirlpool Dryer switch at bottom of heating element (Dryer Repair)
by Roosterwes 10/18/2016 12:06:25 PM(UTC)
Dryer switch does not turn on. (Washer Repair)
by yalda 7/31/2012 3:36:51 PM(UTC)
Dryer switch wiring (Dryer Repair)
by talon636 6/27/2012 7:53:19 AM(UTC)
Repair a Dryer Switch (Dryer Repair)
by jmarkk1 5/31/2012 9:25:49 AM(UTC)
Replaced dryer switch but won't stay on (Dryer Repair)
by taminator 1/19/2012 9:18:24 AM(UTC)
by janrauenhorst 3/30/2011 10:56:58 AM(UTC)
dryer switch (Dryer Repair)
by dorena vaccaro 12/13/2010 7:31:18 AM(UTC)
Maytag dryer switch went bad (I thought) but new switch is doing the same thing. (Dryer Repair)
by woof 11/18/2010 10:36:08 AM(UTC)
Maytag Dryer Switch Problem (Dryer Repair)
by kenkane 10/1/2010 1:53:37 PM(UTC)
Dryer switch intermittent (Dryer Repair)
by jcw99 9/30/2010 5:45:28 AM(UTC)
Update on dryer switch problem? (Dryer Repair)
by jhuffar 6/22/2010 8:49:30 AM(UTC)
Need to replace dryer switch (Dryer Repair)
by cojo 4/28/2010 7:33:28 AM(UTC)
