AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Kenmore washer agitates on heavy duty but not on permanent press or normal
This is before and after new timer!
Any ideas or suggestions greatly appreciated.
M/N 11092375100
In order to provide the most accurate advise I need the complete model number of the washer.
Originally Posted by: Gene In order to provide the most accurate advise I need the complete model number of the washer.
Gene. M/N 11092375100
There is a two speed motor on your washer. Most likely it does not work on the high speed due to the bad high speed motor winding, loose connection at the motor plug or a broken wire. - The part number for the motor is AP2905451 Gene.
Originally Posted by: Gene There is a two speed motor on your washer. Most likely it does not work on the high speed due to the bad high speed motor winding, loose connection at the motor plug or a broken wire. - The part number for the motor is AP2905451 Gene. Ill check it out tomorrow. With your help I know what to look for. Thanks a bunch!
Keep me updated, please.
Originally Posted by: Gene Keep me updated, please.
Gene. I will. Thanks again.
Well, I disassembled washer this morning and did not find any loose or broken wires. So I guess the motor is bad. However I did notice an electrical part (I think would be a capacitor, Part Number: AP3861916) near the motor. Could it be faulty?
Thanks,
Okey
The motor will not run at all with a bad capacitor.
Washer Repair
