2 Pages12>
jkammer
#1 Posted : Monday, November 2, 2009 9:41:04 AM(UTC)
jkammer
The dryer has stopped spinning - assuming that the motor has died - are there any other things to consider? Thanks to all.
gabe_1981
#2 Posted : Monday, November 2, 2009 10:26:17 AM(UTC)
gabe_1981
The model number indicates that this is an electric dryer ... The first thing I would do is make sure there is 240v at the wall outlet.
jkammer
#3 Posted : Monday, November 2, 2009 10:35:08 AM(UTC)
jkammer
Thanks Gabe - yes it is 241 V.
gabe_1981
#4 Posted : Monday, November 2, 2009 10:52:03 AM(UTC)
gabe_1981
Ok now that we know we have proper voltage at the outlet we need to check the door switch ... With the dryer door open, the switch lever will be in the upper right side of the door housing ... press and release that lever and listen for it to make a clicking sound.
jkammer
#5 Posted : Monday, November 2, 2009 11:45:10 AM(UTC)
jkammer
Yes - it is clicking.
gabe_1981
#6 Posted : Monday, November 2, 2009 12:33:06 PM(UTC)
gabe_1981
Ok after unplugging the dryer pull the small panel right above the spot where the cord enters the dryer ... Behind that panel you will see the 3 leads that attach the cord to the dryer ... Check for burnt wires at that connection ... If thats good pull the back panel of the dryer and check to see if the thermal fuse reads open using and oam meter... The thermal fuse will be white plastic with two wires goin to it ... It will be located on the blower housing.
jkammer
#7 Posted : Monday, November 2, 2009 1:01:25 PM(UTC)
jkammer
The hot/neutral/ground look clean.
The thermal fuse (blue and orange wires entering leads on white plastic) read 0.1 ohms.
I have this darn thing open and still can't seem to find the motor - what's up with that?
gabe_1981
#8 Posted : Monday, November 2, 2009 1:09:58 PM(UTC)
gabe_1981
For testing sake pull the wires from the thermal fuse and test to see if the fuse is closed ... Its normaly closed and if it reads open it should be replaced ... I dont advise it but the fuse can be bypassed by putting the two wires together.
jkammer
#9 Posted : Monday, November 2, 2009 1:29:47 PM(UTC)
jkammer
Pulled both wires and got the same reading of 0.1 ohms - is it bad?
gabe_1981
#10 Posted : Monday, November 2, 2009 1:37:24 PM(UTC)
gabe_1981
The ohm reading seems really low to me ... Put the two wires together making sure they make good connection ... with the exposed part of the wires away from any metal it can ground out on plug the dryer in and see if that fixes the dryer
ROPER Dryer not spinning (Dryer Repair)
by tt2601 10/3/2013 12:55:01 PM(UTC)
Amana Dryer not spinning (Dryer Repair)
by ccasler 3/8/2010 7:40:19 AM(UTC)
by cozmo 9/26/2007 2:20:04 PM(UTC)
2 Pages12>
