powers7000
#1 Posted : Sunday, November 1, 2009 10:47:38 AM(UTC)
powers7000
My 27 inch model 110.60942990 Kenmore Elite dryer no longer generates any heat. All other functions seem to work properly. I can't see how to access the heating element. Need a diagram and any troubleshooting steps would be greatly appreciated.
SublimeMasterJW
#2 Posted : Sunday, November 1, 2009 11:01:54 AM(UTC)
SublimeMasterJW
Access this dryer's stuff by dropping the kick plate. Use a putty knife to release the springclips atop dat kick plate. Note: you cannot access this dryer from the rear
UserPostedImage
A manual that features this type dryer.:D
page 15 shows an illustration of how to remove dat
toe panel all propah.
#3 Posted : Monday, November 2, 2009 12:58:08 AM(UTC)
You may want to check that you have 240 volts.
Turn the breaker off/on a couple times. Sometimes you can loose half the line without tripping the breaker and the heater requires the full 240.
Better yet measure it with a meter.
Qtip
#4 Posted : Monday, November 2, 2009 7:55:07 PM(UTC)
Qtip
If dryer is getting 240v check Thermal fuse and Thermal Cutoff (for continuity) and heating element also for continuity. One or all may need replaced (any of those that do not show continuity go ahead and replace). Fuses and Heating elem usually blow out because of restricted airflow in vent hose.
Guest (5)
Kenmore model 11060022010 electric dryer no heat (Dryer Repair)
by mike5466 5/1/2020 10:29:22 AM(UTC)
Speed Queen electric dryer no heat after 5 min. (Dryer Repair)
by napalm747 8/23/2014 6:05:30 PM(UTC)
electric dryer no heat - problem solved (Dryer Repair)
by JohnWMc 6/2/2014 3:17:26 PM(UTC)
Electric dryer no heat (Dryer Repair)
by Timothy Burt 4/10/2014 12:02:47 PM(UTC)
Whirlpool Electric Dryer No Heat (Dryer Repair)
by ahrjmrecr 10/30/2013 2:38:30 PM(UTC)
whirlpool duet electric dryer no heat (Dryer Repair)
by Reisingera03 2/6/2013 2:49:42 PM(UTC)
by CSteidl 8/14/2012 11:59:05 AM(UTC)
by livetoride2112 3/5/2012 5:24:19 PM(UTC)
Maytag Neptune Electric Dryer No Heat (Dryer Repair)
by jrvier 11/12/2011 3:31:42 PM(UTC)
kenmore electric dryer no heat (Dryer Repair)
by vito m 5/18/2011 6:00:36 PM(UTC)
Sears Galaxy Electric dryer no heat,timer doesn't move (Dryer Repair)
by melindascrochet 5/2/2011 7:38:20 AM(UTC)
Whirpool Electric Dryer No heat (Dryer Repair)
by flmeade 9/14/2010 8:38:15 AM(UTC)
EstateElectric Dryer No Heat (Dryer Repair)
by elaza 6/5/2010 8:00:42 AM(UTC)
by STEVE8369 3/16/2010 3:53:24 AM(UTC)
by MIKEK38E 2/9/2010 5:25:07 AM(UTC)
