Can I change the coils on the burner without removing the burner assy. Simply remove the front cover [housing] and have access to it?
is it possible to remove and replace coils on the burner assy without removing the assy itself, looks like remove the front panel and hope to get access to them.
Cannot find any info on this unit, tried 2 sites. Please check your model number.
Note if it is not a US unit it will be difficult to find info. |
THIS FORUM IS DEAD!!!!!!! |
