2 Pages<12
mixerman
#11 Posted : Wednesday, October 14, 2009 12:13:52 PM(UTC)
mixerman
pic of rear of oven knob. And in the oven. The out tube from the knob goes into the oven then just under it is the smaller tube that goes to the valve that at the bottom of the oven, then under that is the small prob. When you turn on the oven dial there is a little pop you can hear in the knob. The wires from the knob have been wire nutted to one power wire. Thanks Dave UserPostedImage
mixerman attached the following image(s):
SublimeMasterJW
#12 Posted : Friday, October 16, 2009 4:12:15 PM(UTC)
SublimeMasterJW
Thats looks like the standard safety valve used by sears kenmore but you need to remove it and compare it with a newer one. I would bet you need to replace this valve
UserPostedImage
UserPostedImage
SublimeMasterJW
#13 Posted : Friday, October 16, 2009 4:26:56 PM(UTC)
SublimeMasterJW
That looks like a 4060-701 robertshaw gas oven safety valve
Robertshaw Gas Oven Controls - Robertshaw Replacement Kits, Safety Pilots, Safety Valves
4060-700 (MSC)
Used with CS4700 ā€œUā€ series thermostats in lo-temp. 140° F. to 550° F. oven systems. Inlets are 3/8" or 7/16" tubing. Orifice hood outlet.
Part Number
Description
4060-701
15" capillary
4060-702
24" capillary
UserPostedImage
SublimeMasterJW
#14 Posted : Friday, October 16, 2009 4:30:09 PM(UTC)
SublimeMasterJW
It would be better if you removed the valve and matched it up.
All of them work the same way though. But not all use the same size connections. It is a pisser
SublimeMasterJW
#15 Posted : Friday, October 16, 2009 4:38:46 PM(UTC)
SublimeMasterJW
The new part number on these is 4060-901
I found one online for 20 bucks:
Guest (5)
2 Pages<12
