cdodge
#1 Posted : Wednesday, October 14, 2009 8:55:05 AM(UTC)
cdodge
My washer does'nt spin.It washes,drains but does'nt spin.The only time it spins is when it is empty.I replaced the electronic board on top.I got it to spin twice with 2 towles in it in about 10 tries. Ser# is HLT4353286.
sidfink43
#2 Posted : Thursday, October 15, 2009 3:59:20 PM(UTC)
sidfink43
See if you can find the tech notes with trouble shooting routines, either under the top or inside the bottom panel.
A probable cause is your motor control board, but it is very expensive and you do not want to replace it unless you are sure that is the problem.
cdodge
#3 Posted : Friday, October 16, 2009 5:46:24 AM(UTC)
cdodge
I got the tech notes and ran A diagnostic test and everything worked it would even spin at high speed. I cant get A erroe code. Plus now I can't make it run the clean washer cycle without A F34 code with nothing in it.
sidfink43
#4 Posted : Friday, October 16, 2009 8:27:34 AM(UTC)
sidfink43
Well, based on this information I would suspect the main board, but you have already replaced it.
It is possible, maybe even likely the main board you received was defective, and I would see if you can get an exchange on it. That way you will either have it fixed or know for sure the main board is not the problem.
cdodge
#5 Posted : Tuesday, October 27, 2009 7:38:36 AM(UTC)
cdodge
I replaced the ccu board and the touch pad board. What next? There is no change.
sidfink43
#6 Posted : Tuesday, October 27, 2009 12:39:41 PM(UTC)
sidfink43
See if there is anything in the tech notes about testing the motor control unit.
washer don't spin (Washer Repair)
by jbrunetquixtar 7/4/2009 5:40:58 AM(UTC)
